Author Topic: Servos twitching  (Read 6278 times)
Offline r2d2
  • Full Member
Servos twitching
« on: November 17, 2010, 04:36:46 PM »
Hi all, after setting up my electronics found that all my servos are twitching. They do follow TX commands but in an erratic way. Any clue?
Thanks
Arturo
HK450 V2
HK450Pro
Hurri 425
sandbar521
Re: Servos twitching
« Reply #1 on: November 17, 2010, 06:24:07 PM »
Hey r2d2,if you tell us what electronics your using as well as what radio system,I'm sure you will get some pretty good answers from all the fine pilots on here. :125:
Offline HBFP NL
  • Happy Flying!
    • Happy Flying
« Reply #2 on: November 18, 2010, 01:00:49 AM »
Do you have your power line seperated from the other wires,  like the esc wire on the left and the rest on the right....
My RC foamy & heli Blog: http://www.happyflying.nl
Offline r2d2
  • Full Member
« Reply #3 on: November 18, 2010, 07:34:01 AM »
Electronics are:
HK401B Gyro
Hobbyking SS Heli Series 50-65A ESC
OrangeRx Spektrum DSM2
ZIPPY Flightmax 2200mAh 3S1P 20C
HXT900 9g Micro Servo for collective
DS65HB Digital High Speed Servo 6.5g for rudder
Tx is a Spektrum DX7
Power line from ESC's BEC is not separated from servos wires yet. I have all wiring outside Heli just during setup, but will take that as a good advise  :130:
I fully charged my battery and that reduced significantly twitching amount, but still present mainly at center sticks.
Sometimes it stops by moving a little any stick but it actually works well when moving throttle stick. Motor is not connected yet (missing connector but they are now on their way here).
So.... any ideas?
Arturo
HK450 V2
HK450Pro
Hurri 425
sandbar521
« Reply #4 on: November 18, 2010, 08:17:47 AM »
When I was building my HK600GT,a couple of my servos pulsed or twitched and it turned out to be the links from the servo horns to the push-pull mechanism's that then go to the swashplate were not quite long enough therefore putting too much pressure on the servo gear itself.So after scratching my head for a while I adjusted my links a little longer,but yet equal lengths,and the reduced pressure on my servos fixed the problem.Hope this helps. :propeller:
Offline r2d2
  • Full Member
« Reply #5 on: November 18, 2010, 09:13:10 AM »
Thanks, twitch problem appear even before set links or control horns on servos. My first approach was to bind TX and RX and then connect all components electrically to confirm proper function that's when twitch appear.
I think its more an interference issue....
Greetings
Arturo
HK450 V2
HK450Pro
Hurri 425
Gene T
« Reply #6 on: November 18, 2010, 02:06:52 PM »
I had a bad servo that caused other servos to twitch. What was funny is that the servo would be stable when the heli was on it's right side, but twitch like hell if the heli was on it's left side. Replaced one bad servo, the others were fine.
Offline r2d2
  • Full Member
« Reply #7 on: November 18, 2010, 02:50:06 PM »
I will unpluged one by one and test different combinations and see what happens...
Someone told me not to mix power wire from ESC with servo wires. I change setup to send ESC wire at right side of bird and servos on left.... same result :215:
Greetings
Arturo
HK450 V2
HK450Pro
Hurri 425
Offline RobHop
  • New member
« Reply #8 on: November 19, 2010, 06:00:35 AM »
I had the same problem as Gene T described, 1 bad servo affected the rest so maybe this is the problem...
HK-500GT, HK-450GT, HBKing3, HBKing2(fully pimped) Walkera 1#B, 22e, & several 4ch's.
Offline r2d2
  • Full Member
« Reply #9 on: November 19, 2010, 06:44:09 AM »
I found source problem. As my other thread says, my ESC's BEC is giving 8V and that is what causes twitching!
I had a RX battery from my old airplane stuff, charge it, test it and hooked it to my setup and that's it..... twitching is gone! :220:
Only problem is that I will need a new ESC... :212:
Any good advise? I was watching for Hobbywing 40A
Greetings
Arturo
HK450 V2
HK450Pro
Hurri 425
Offline HBFP NL
  • Happy Flying!
    • Happy Flying
« Reply #10 on: November 19, 2010, 08:45:16 AM »
I use 2 Turnigy Plush 40A and like them very much.
I also had the budget TP 40A which was nice to, I added and extra bec with the TP as it gave 2Amp.
sandbar521
« Reply #11 on: November 19, 2010, 10:35:34 AM »
I use the Volcano series and like them alot. :propeller:
Offline WildBird22
« Reply #12 on: November 19, 2010, 03:25:14 PM »
Glad to hear you found the source.
I like the HobbyWing ESC....
http://www.helidirect.com/brushless-escs-hobbywing-c-1_1619_45_434.hdx
Offline caddmus
  • My wife says I look like Gru
« Reply #13 on: November 21, 2010, 08:38:23 PM »
Tarot 500FL, Trex 500, Trex 500FL PRO, Trex 600, Trex 600E Pro, Airwolf 600, Trex 700, Mikado XXTREME.
…pəʇɹəʌuɪ ʎɐʇs ʇoʅɪd pooƃ ɐ əɹɐ noʎ  Ɉɪ…
