Author Topic: Changing Kbar Bluetooth pairing code  (Read 1671 times)
0 Members and 1 Guest are viewing this topic.
Offline crasher47
  • New member
« on: April 21, 2015, 03:01:00 AM »
I have a Trex 450 setup with a Kbar and the blue tooth module.  I am in the process of setting up another heli, a Trex 500 with the same setup.  Will it be necessary to change the pairing code for the blue tooth module?  If so how would I go about doing it?
Offline Davesheli
  • Administrator
  • Legend
    • RumblecloudRC
Re: Changing Kbar Bluetooth pairing code
« Reply #1 on: April 22, 2015, 04:09:55 AM »
Sorry Crasher, I don't have an answer for you, I hope someone else will be along shortly to help out, right now with work and family I don't have much time to research the question either...  :saad:
Good luck and let us know if you happen to find the answer or figure it out....
DH....
